Skip to content
前端部署 ​
本地调试 ​
信云+部署 ​
业务方首先需要将脚手架代码上传至业务方的Git代码仓库后再进行信云+部署,在信云+的部署操作请参考Devops 使用手册,这里只提供部署时需要的相关配置。
PC 端工程 ​
  • 流水线代码编译脚本
bash
# 脚本运行过程中日志冗余输出
set - x
# 进入从git仓库拉取下来的代码目录下 , #{前端代码根目录需}要根据业务方实际情况配置
cd pangea-web-vue3
# 设置仓库
pnpm config set registry http://nexus.hisense.com/repository/npm-public/
pnpm install
# 命令中“:”后的编码dev、test、uat、prd分别对应开发平台右上角开发、测试、预发、生产四个环境
pnpm run build:dev
  • nginx 中 default.conf 配置文件
bash
server {
    listen 8080;
    server_name localhost;
    underscores_in_headers on;
    #默认主页d
    index index.html;
    #跨域问题
    add_header Access-Control-Allow-Origin *;
    add_header Access-Control-Allow-Methods 'GET, POST, OPTIONS';
    add_header Access-Control-Allow-Headers 'DNT,X-Mx-ReqToken,Keep-Alive,User-Agent,X-Requested-With,If-Modified-Since,Cache-Control,Content-Type,Authorization';
    #静态页面目录
    root /tmp/static;
    client_max_body_size 2048m;
    proxy_connect_timeout 12500s;
    proxy_send_timeout 12000s;
    proxy_read_timeout 12000s;
    # 配置主页信息
    location / {
    	try_files $uri $uri/ /index.html;
    # 对象存储代理
    location /minio/ {
        proxy_pass #{对象存储地址};
    # 前端代码编辑器
    location /node_modules/ace-builds {
        proxy_pass https://symamicro.hisense.com;
    # AI组件相关智能体API
    location /higpt/ {
        proxy_pass https://inner-apisix.hisense.com/;
    # 轻卡片配置
    location /symaMicro {
        proxy_pass https://symamicrodev.hisense.com;
    # 后端网关代理
    location /api/ {
        proxy_pass #{网关地址};
        proxy_set_header Host $host;
        proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
        proxy_set_header authorization $http_authorization;
        proxy_cookie_path /project /proxy_path;
    # 统一鉴权代理
    location /auth/ {
        proxy_pass #{网关地址};
  • nginx 中 nginx.conf 配置文件
bash
user nginx;
worker_processes 1;
error_log /var/log/nginx/error.log warn;
pid /var/run/nginx.pid;
events {
 worker_connections 1024;
http {
 include /etc/nginx/mime.types;
 default_type application/octet-stream;
 log_format main '$remote_addr - $remote_user [$time_local] "$request" '
 '$status $body_bytes_sent "$http_referer" '
 '"$http_user_agent" "$http_x_forwarded_for"' '"$http_cookie"';
 access_log /var/log/nginx/access.log main;
 sendfile on;
 #tcp_nopush on;
 keepalive_timeout 65;
 # 开启 gzip_static 模块 (关键配置)
 # 开启后若存在同名gz文件将直接返回不进行压缩
 gzip_static on;
 gzip on;
 gzip_min_length 1k;
 gzip_buffers 8 16k;
 gzip_comp_level 4;
 gzip_types application/x-javascript application/javascript application/octet-stream text/css text/javascript image/jpeg image/gif image/png image/x-icon;
 gzip_vary on;
 gzip_disable "MSIE [1-6]\.";
 include /etc/nginx/conf.d/*.conf;
注意: nginx 配置文件中#{xxx} 需要替换为真实地址,请联系 Pangea 团队获取真实地址。
移动端 ​
  • 流水线代码编译脚本
bash
# 脚本运行过程中日志冗余输出
set - x
cd pangea-uniapp-vite
# 设置仓库
yarn config set registry http://nexus.hisense.com/repository/npm-public/
yarn install
yarn run build:h5:dev
  • 镜像构建 Dockerfile
bash
FROM registry-dev.hisense.com/registry-ocp/nginx:static
ADD ./h5/ /tmp/static/uni/
ENV TZ=Asia/Shanghai
USER nginx
bash
server {
    listen 8080;
    #默认主页d
    index index.html;
    #跨域问题
    #静态页面目录
    root /tmp/static;
    # 配置主页信息
    location / {
    	try_files $uri /uni/index.html;
    # 对象存储代理
    location /minio/ {
    # 资产中心
    location /walnut/ {
        proxy_pass http://walnut-plugincenter-pangea-publicserver-prd.cloudprd.hisense.com;
    # 后端网关代理
    location /api/ {
        proxy_pass #{网关地址};
    # 统一鉴权代理
    location /auth/ {
        proxy_pass #{网关地址};
  • 健康检查配置
    注意: 端口的配置应根据业务方实际部署时填写。
